Death wobble
Old Feb 24, 2013 | 05:32 PM
k.baker B.D.O.R's Avatar
Default Death wobble
I seem to have this constant shake in he front with every little bump it feels like it want to take off in a full dw but doesn't but makeup hard to drive wondering what I can do to cure it I've balanced the tires had it on the alignment rack a lot and yet nothing seems to be out of wack I've checked the track bar bushings they are all tight I'm running dual skyjacker stabilizers idk what else to do
Old Feb 24, 2013 | 06:38 PM
planman's Avatar
Forum Tech Advisor
Have you watched my videos and read my write-up thread?
Old Feb 25, 2013 | 02:07 AM
I have I want to change the bolts and try that maybe that's it but idk the jeep just recently started this I knew the previous owner ad I don't remember it doing this to him
Old Feb 25, 2013 | 05:16 AM
JKPhoto's Avatar
I just ended this problem...
installed Teraflex track bar, new ball joints and steering stabilizer. Then had the front end aligned. Drives like a champ.
I had gone a bit over 40k before the issue started. Jeep is no help with this problem. I had been to multiple shops trying to get it fixed. In the end $$ on new parts and labor was the solution.
Old Feb 25, 2013 | 07:22 AM
The jeep only has 10 k miles and stabilizers are new and I have rk track bar
Old Feb 25, 2013 | 07:32 AM
shockwaveaz's Avatar
Did you torque everything back down after your lift break in period? Also make sure that track bar is tight. Takes a lot of torque to get it to spec.
Sent from my Galaxy Note 2
Old Feb 25, 2013 | 09:09 AM
I've retightened everything many times
Old Feb 25, 2013 | 09:57 AM
ZMagic97's Avatar
Tried rotating the tires and making sure all of them are at the same PSI?
Old Feb 25, 2013 | 01:42 PM
I did rotate had tires rebalanced and did check the psi
Old Feb 25, 2013 | 01:45 PM
kjeeper10's Avatar
Vet Army
Alignment specs ?
