Death Wobble Continues...
Old Jul 28, 2010 | 09:39 AM
RED_RUBI_07's Avatar
Default Death Wobble Continues...
After having dealt with this for months and torquing every component to spec according to Project JK's listing and checking it every 2 weeks I'm at a loss. Does anyone think adjustable control arms would help the situation? I'm sitting on a TF 2.5" coil lift, stock rims tires, and wheel spacers.
Old Jul 28, 2010 | 10:03 AM
ROKmarine's Avatar
Have you checked all the joints for wear/failure? Or checked the mounting brackets for failure? Not even close to an expert, but just something I've read about. As for lower control arms, I have the teraflex ones and they work great, but not sure if it would fix your problem.
Seriously good luck man, I hope you find a solution.
Cheers
Old Jul 28, 2010 | 10:12 AM
Originally Posted by planman
Do you have DW like the video in my DW Write-Up thread, or is it more of a non-DW shimmy?
Sent from my Droid using Tapatalk
It's definitely Death Wobble. The jeep will shake uncontrolable until until you come to a stop. the steering is flighty but i figured that was because i didn't have adjustbale control arms.
Old Jul 28, 2010 | 10:15 AM
Marshall's Avatar
Im sure you already did this......but, did you check your track bar, and make sure everything was torqued properly?
Old Jul 28, 2010 | 10:31 AM
Hellbound13's Avatar
Remove both your front and rear trackbars. Check the bushings for wear and check the trackbar mount holes on the axle bracket for wallowing.
