Death Wobble in the making....???
Old Apr 6, 2011 | 07:42 PM
scamp_71's Avatar
Default Death Wobble in the making....???
I installed the TF leveling kit about 2 months ago and my JK drove like stock after the install. The last couple of weeks I've noticed a very slight oscillation in the steering wheel when I hit any bump or pothole in the road. Now granted, I haven't checked the torque on any of the bolts beyond a visual inspection since the install, but everything appears to be tight. Could something be a little loose causing this? Anyone else experience this over a little time with the leveling kit? I'm not particularly worried that it's problem, but don't want to have it turn into a problem either.
Old Apr 6, 2011 | 07:57 PM
cfr's Avatar
cfr
Check planman's death wobble thread for the definitive checklist.
https://www.jk-forum.com/forums/show...es-and-Wobbles
The short version is re-torque everything with the jeep's wheels on the ground first. Real death wobble (almost sh!% your pants) is usually the front track bar.
Old Apr 6, 2011 | 08:02 PM
stratman2's Avatar
Everything needs to be torqued to factory specs. could be loose bolts, oblonged holes, worn ball joints or any combination of those. I would bet that you will see a difference once you tighten everything with a torque wrench.
