Degree Wedges or Adjustable Coil Spring Mounts?
After I installed the new adj control arms, I found out my rear coils got bowing right now.
I know there are some ways to solve this issue, but which is better?
1: Get a pair of degree wedges from Rock Krawler.
2: Get a pair of adj rear coil springs mounts from JKS.
Thanks!
Thanks!
They both work.
Call David. He is the first (and generally ONLY) call I make for JK farkle.
http://www.northridge4x4.com/proddet...rod=CE-9807RRK
Thanks for the replies! I have an another problem, my rear right bump stop is making contact with the rear track bar bolt located on the top right track bar bracket when the vehicle is getting bumped. Is there any good idea to get this issue solved? Thanks
