Desert Driving
Old Feb 20, 2012 | 07:51 PM
flipper5's Avatar
Terraflex has a Long Travel System and it uses a Long Arm Kit I believe.
Old Feb 20, 2012 | 07:53 PM
Prime8's Avatar
Originally Posted by Quentin_T
This:
pretty sure that car is in Mad Max... haha...
Old Feb 22, 2012 | 11:17 AM
LBJEEPER's Avatar
I'd throw Teraflex's pre-runner kit in the mix or maybe even just their limiting straps and bumps. Or you could also do another aftermarket bump stop and the EVO bump can's. Just my two cents
Old Feb 22, 2012 | 11:20 AM
ZMagic97's Avatar
Airing down and keeping it in the higher revs as stated before is really the best thing to do. I run around a lot in the desert as decent speeds even when not airing down. All about skill, some gear, and a lil luck IMO.
Old Feb 22, 2012 | 12:37 PM
Christarp's Avatar
and what should I do if I have a *gasp* automatic? Going to the dunes in Oregon in about a month, just ordered a trans cooler, but there's really not a way to control my gears. Should I 4-hi in first and second only, or should I just 4-hi in D with overdrive off? or 4-low in drive with overdrive off? Sorry for kinda hijacking this thread, just a bit curious.
Old Feb 22, 2012 | 12:39 PM
ZMagic97's Avatar
For an auto, make sure the O/D is off, 4hi or 4lo depending on conditions.
Old Feb 22, 2012 | 12:47 PM
MrDillClinton's Avatar
You're considering a Hemi swap but a lift kit sounds expensive?
I advise you to think about your priorities a bit more before you start buying parts.
You could sell the JK and get the Rally or Raptor....this would be a much easier route.
JK's aren't meant to go fast. You need something with IFS.
Old Feb 22, 2012 | 02:02 PM
UAE455's Avatar
The Raptor is a huge truck and JKs look sweet with everything off , we use the polaris rzrs in the dunes most of the time and with the cost of it and upgrading its too much not to mention towing it there. With perfectly setup Jeep I would just go on/off road without hassle. It's not only for fast driving maybe some jumping adde to the mix.
Old Feb 23, 2012 | 04:29 AM
ammar's Avatar
Default Evo dtd
Best way to do it is the EVO system. have a look at this video and see what one of they guys could do with his JK, it also had a hemi.
http://www.youtube.com/watch?v=JgN5XuNNOhA
He spent a lot of money but did it right i guess.
