Determine amount of actual lift.
Old Feb 24, 2014 | 09:29 AM
BossierCity_Jk's Avatar
Default Determine amount of actual lift.
Is there a set height for stock jks coil spring length axle to perch? I added bumpers and my front looks a little lower. Like how tall should a 3.5 spring sit while jeeps on the ground? I know the rubicon vs sport to 2 and. 4 door matters but there has to be stock numbers! Help?
Old Feb 24, 2014 | 10:33 AM
gunbo75's Avatar
Go to a dealer and compare the jeep like yours by measuring .
Old Feb 24, 2014 | 10:35 AM
Anyone, there has to be stock specs for a jk 2dr islander or at least sport and rubi? I might just go measure another islander that's forsale that just like mine. Be easier to just know the specs
Old Feb 24, 2014 | 10:48 AM
Maertz's Avatar
Old Feb 24, 2014 | 03:29 PM
Invest2m4's Avatar
That's awesome! That should go to the stickies. I see a related question to that at least once a week.
Now, the $60k question: do you have the same spec for the rear?!?!
Old Feb 24, 2014 | 03:37 PM
Maertz's Avatar
negative, but you can assume if your jeep is sitting level you got a good 1/2-1" more in the rear (depending on weights of course)
Old Feb 24, 2014 | 04:29 PM
ronjenx's Avatar
Here are the curb height measurements for the different stock JKs, and pictures showing where to measure:
Old Feb 24, 2014 | 04:40 PM
jaker t5's Avatar
Originally Posted by Maertz
That does not work , by that picture I have a 5" lift with full bumpers and some armor when I have a 4" lift
Old Feb 24, 2014 | 04:43 PM
jeepmojo's Avatar
Default this measurement would be lifted on frame no weight
so wheel off and jacked up ? Or is this ground height ?
Old Feb 24, 2014 | 05:20 PM
Maertz's Avatar
on the ground. has worked on my jk and many others, not sure why jakers isnt working possibly he netted more than he thought?...i did not make it its just one ive seen posted many times and has been at least ballpark everytime ive used it.
