Detroit Truetrac Differentials
Old Jul 13, 2012 | 07:41 AM
Cascade Wanderer's Avatar
Veteran: Marine Corp
Default Detroit Truetrac Differentials
Have a new, base model 2012 two-door. All stock except a set of 265's on 16" rims. V6 & six-speed manual. Have owned 4x4's for over 30 years so I do have some experience.
I don't anticipate doing real "rock crawling" - just using this Little Rascal to get me to and from the fishing and camping spots, and places where I want to hike, mountain bike or cross-country ski. Live in snow country here in Central Washington. I've had conventional limited slips in the past, was very pleased with one from Auburn in an ol' K5 Blazer I had some years back.
The Detroit Truetrac Differentials by Eaton were recommended to me - and I wondered if any of you are running them, rear diff, or front and rear. Thoughts?
Am looking to do minimal mods to the Wrangler, some sort of diffs, a winch, a rack or two to carry my other outdoor toys. That's about it, and about all I've ever needed from my 4x4's - just don't have any experience with the Truetrac diffs.
Ease of driving with one in the front? I use 4wd a lot in the winter on paved roads, particularly when we get a heavy dump of snow overnight.
Thanks in advance for your input!
Regards, CW
Old Jul 13, 2012 | 09:26 AM
timh1955's Avatar
Excellent equipment. I had a set in my Dana 40 on my Jeep Commandor. It took care of all of my needs (rutted/washed out forest roads/ranch roads etc.)
well worth the $
Old Jul 13, 2012 | 09:50 AM
tslewisz's Avatar
I love 'em in my JK, front and rear.
Old Jul 14, 2012 | 12:54 AM
ghostjk's Avatar
I am also very interested in everyone's experience and opinion of the best use for trutrac application
Old Jul 14, 2012 | 03:38 AM
archijeff's Avatar
Detroits are awesome lockers and easy to install compared to ARB (which I think are the only thing better than Detroit)... Personally I never run fronts unless krawling or a high pitch approach.
As for the trulocks, I have very little experience with them due to immediate ARB conversion
Old Jul 14, 2012 | 03:39 AM
archijeff's Avatar
Sorry.. Truetraks
Old Jul 14, 2012 | 03:54 AM
renegade4x4's Avatar
You said an all stock 2012... that means stock gears and a truteac will not bolt in, in th me rear. The rear ring gear is drilled for half inch bolts and the trutrac is only drilled for 7/16" bolts.
I have spoken with a Rep at Eaton and they have confirmed this. They also said at a 58-59 Rockwell hardness rating it would be very hard to drill to accommodate the larger bolts.
Why hasn't this issue been a problem in the past? The 07-11 Jeeps were undergeared from the factory and most replaced with aftermarket gears so this is a nonissue.
Bolt in choices for the 2012 rearend are a grizzly locker or zip locker from Yukon. And of course stock traclok.
Hope this helps.
Old Jul 14, 2012 | 05:15 AM
Thanks, and yes, I'd heard that about the bolt sizes... Interesting twist on things isn't it?
Of course one workaround would be to drop the gear ratio too... Not a bad thing at all.
CW
Old Jul 14, 2012 | 06:52 AM
CerOf's Avatar
Under full throttle on an icey/snowy road you can crab walk. Ran front and rear on my old zj. Worked great!
Old Jul 14, 2012 | 10:53 AM
ghostjk's Avatar
Dynatrac said you could drill it out to the 1/2 in bolt size and that it wasn't that big an issue. Especially if you have a drill press. I figured I could order one from north ridge and pay em extra to drill the holes out for me. It is a custom shop
