Detroit TruTrac help!
Old Jun 17, 2011 | 07:45 AM
GunDude's Avatar
Default Detroit TruTrac help!
I want to order a TruTrac for the rear D44 in my 2011 JK, but I am not sure if I have the right part# 913A589. All I have found say this is part number up to 06' and 3.73's and lower. I want it for my D44 with 3.73. Anyone help out with Eatons part#!
Old Jun 17, 2011 | 07:51 AM
sacdaddy03's Avatar
I believe you should be looking for this one...But a vendor could point you in the right direction.
http://www.quadratec.com/products/16100_612.htm
Old Jun 17, 2011 | 08:12 AM
GunDude's Avatar
Yep, I saw that one, but was wanting eaton's part number so I could shop around! I found out that the 07' up do not have a carrier break.
Old Jun 17, 2011 | 08:24 AM
sacdaddy03's Avatar
hxxp://www.summitracing.com/search/D...?Ns=Rank%7cAsc
DTL-913A590 Fits the best description far as I can tell...
Old Jun 17, 2011 | 08:50 AM
Dynatrac's Avatar
Sponsoring Manufacturer
The correct Truetrac part number for a JK 44, any ratio (because of 'thick' gear), is 913A589. Keep in mind that you may have to re-drill the Truetrac to accept the 1/2" ring gear bolts used in most JKs built after mid 2007.
Old Jun 17, 2011 | 11:17 AM
mkjeep's Avatar
Just like the reg. detroit locker I got I suppose. Kinda freaked me out abit, but it drilled like butter, and its not really much you drill out anyway.
Old Jun 17, 2011 | 11:36 AM
Mad-Hatter's Avatar
Only bummer is, the truetrac case is a lot harder to drill due to the hardened material
Old Jun 17, 2011 | 12:12 PM
Dynatrac's Avatar
This is true. The hardened case make the job pretty difficult.
