did you install prorock axle yourself?
Old 12-04-2012, 03:04 AM
rtguy1's Avatar
dont get confusd about the hybrid axle. it is a dana 44 axle with dana 60 ends. not a 60 with a 44 housing.
Old 12-04-2012, 03:52 AM
bo9roadking's Avatar
I thought it was a 44 with 60 knuckles too, but when I discussed a 44/60 hybrid build with Scott at Dynatrac before I chose the 44 Unlimited, I thought he told me that it was a D60 with a 44 pumpkin. I may have misunderstood him, but with the axle having 35 spline shafts that are 1.5" in diameter, it sounded like a D60 to me.
Old 12-04-2012, 05:11 AM
pontiac31's Avatar
I install the front PR44 using all of my existing factory parts in my garage on Jack Stands. Took about two nights working approx. 2-3 hours per night to swap everything after the broken housing was removed. Very simple if you can remove and reinstall bolts and nuts. I also bought my PR unlimited from Dave at Northridge.
Old 12-04-2012, 05:17 AM
pontiac31's Avatar
Some pics from install.
ID:	395085   Click image for larger version
ID:	395086   Click image for larger version
ID:	395087   Click image for larger version
Old 12-04-2012, 07:53 AM
Sponsoring Vendor
chris@offroadevolution's Avatar
Originally Posted by nmwranglerx
Thanks for the responses and advice everyone. It doesn't sound too bad. I would buy the axle with gears and locker already set up as I wouldn't dare mess with that stuff. I've got some jack stands, a pretty nice floor jack, and lots of hand tools. I've put on a coil lift, installed a 1310 driveshaft, and swapped out a transfer case in my driveway. Basically, just wanted to hear from others in case I was overlooking something. Now I just need to decide whether I'm going 44 or 44/60.
if you have swapped out a transfer case you can handle this...
Old 12-04-2012, 07:59 AM
Sponsoring Manufacturer
Dynatrac's Avatar
This could go either way. The 44/60 Hybrid only differs from a full 60 at the pumpkin. The center section (housing), differential and R&P are JK 44 based but the axle tubes and wheel ends are all D60 based (actually stronger than stock D60). The Hybrid uses a 3-1/8"x1/2 wall tube (like a PR60) and the PR44 uses a 3" by 5/16" (Std) or 1/2" (Unlimited) wall tube.
Many of our customers do this installation in their driveways with basic hand tools and a little bit of mechanical ability. As others have said, you'll need jack stands (required) and a floor jack (not required but recommended) but few 'special' tools are needed. A pickle fork is handy to break loose TREs and you'll want a big hammer.
Feel free to contact me with any questions or concerns.
To all here, we really appreciate your support. This is a great community and we're happy to be a part of it.
Old 12-04-2012, 11:48 AM
kking08's Avatar
i just ordered my pro rock 44 from northridge as well, ive been reading reviews and doing research about swapping everything over and it looks pretty simple. I should have my axle here next week so ill post up a review.
Old 12-04-2012, 12:23 PM
Billnsandi's Avatar
I'd hesitate to depend on a 44 ring gear in the rear of a JK. I've broken two in the recent past without abusing the jeep on 37's.
Old 12-04-2012, 12:32 PM
nmwranglerx's Avatar
Thanks for posting pics, always helps get a better idea
Thanks for recommendations, might be contacting you soon to discuss some of the differences in more detail...
congrats, I'll look forward to seeing the review
Old 12-05-2012, 08:13 AM
dave7200's Avatar
Default also ordered from David at Northridge
I also got my Pro Rock 44 from Dave at Northridge. I ordered it with gears, locker and Dynatrac ball joints already in it. I have 12 ton jack stands so they were just about at their lowest point under the frame making it very solid. If you did coils before you can handle this. I have the Unlimited also and you will notice the Jeep has a more solid feel to it when you go over bumps on the road. I put in RCV shafts at the same time. Be sure and have all the torque specs beforehand for all the different bolts and a good torque wrench. It’s a fun project with a very rewarding outcome.
Quick Reply: did you install prorock axle yourself?
