Diference Between Optima!!!
Old May 29, 2009 | 06:04 PM
tento0929's Avatar
Default Diference Between Optima!!!
i was searching in the net and can find the diference between the oprima red one and the yellow one!!!! with one should one buy???
Old May 29, 2009 | 06:07 PM
bly109's Avatar
red top is a regular starting battery, the Yellow top is a deep cycle. Id go with the yellow top
Old May 29, 2009 | 06:08 PM
cgtweet's Avatar
Default re
Not sure... but I have the yellow top and it runs everything fine for me... lights, winch and cb.
Old May 29, 2009 | 06:24 PM
nthinuf's Avatar
-YellowTop = Deep Cycling/Cranking
Trucks with winches, vehicles with multiple electronics, etc...
-RedTop = automotive starting
Which one should you go with???? You tell us...
KC Fog Modified to HID and Color...
HID Driving Lights
Warn 9.5 ti Winch
JVC 7'' DVD Radio With Infinity Components Front
and JBL Seakers Rear.
2 Amplifiers
Yaesu 2-way Radio
Old May 29, 2009 | 06:38 PM
09rubicon's Avatar
Exactly and you have the blue top as well
Blue=Low cranking amps, continuous deep cycling, recharges quickly
Old May 30, 2009 | 07:27 AM
IMFletch's Avatar
Default Yellow?
So the Yellow top is the best solution for running a winch and aftermarket lights on a Jeep?
Old May 30, 2009 | 08:30 AM
09rubicon's Avatar
Pretty much.
Red = Stock quality replacement
Yellow = Deep cycle replacement with lots of accessories
Blue = Running soley off battery power for extended periods (not good as primary starter)
Old May 30, 2009 | 08:37 AM
IMFletch's Avatar
Then the Yellow top, it is! Thanks.
Old May 30, 2009 | 11:54 AM
ckmehl's Avatar
Default cool tidbit
the red only recharge to 75% of there max. each time you recharge your hurting the cells inside. degradeing the battery.
yellow is limmitless with recharge. will charge 100% everytime. great for high draw from lights and winches. i use these in lager after market steoros. great for off road. planning on running two of them.
Old May 30, 2009 | 05:36 PM
rjhoop's Avatar
yup im gonna go with yellow when mine craps out!!!!!
