Diff Covers or Rock Sliders?
Old Dec 22, 2013 | 07:19 PM
joe002's Avatar
Yeah, a picture's work a thousand words! I have sliders too - glad to have them, but I've only had to "use" them a few times, the diff covers I use more. Most of the time I don't even notice it until I get home and check underneath.
Old Dec 22, 2013 | 07:21 PM
Maertz's Avatar
yeah it depends the wheeling area, ive put my sliders thru hell also. Either way I know the op will get them both eventually anyway!
Old Dec 22, 2013 | 07:27 PM
joe002's Avatar
Yeah, it's pretty rocky here in AZ too, but yeah I'm glad to have both!
Old Dec 22, 2013 | 07:36 PM
OsiViper's Avatar
How do you know that for sure? Lol jk..
I got a list of stuff that would make Santa's naughty list look short.
Old Dec 22, 2013 | 10:02 PM
orangedude71's Avatar
Diff covers first and keep an eye on Craigslist for some rubicon sliders. A bent stock diff cover is a guarantee for a long annoying day if it leaks out its guts
Old Dec 22, 2013 | 10:07 PM
Maertz's Avatar
He has rubi sliders...
Old Dec 22, 2013 | 10:12 PM
missed that, so I still say diff covers and then LCA skids . Rubi sliders are good enough 90% of the time.
Old Dec 22, 2013 | 10:16 PM
4W-Jive's Avatar
They're equally important. Might as well get the sliders while they're on sale. Diff covers are pretty much always cheap. Plus you could start with just the front.
Old Dec 23, 2013 | 01:15 AM
Mark Doiron's Avatar
Originally Posted by OsiViper
Debating between getting some PSC Diff Covers or OR-FAB Rock Sliders while the discount is still in effect. ...[and from profile]
Suspension:
Stock (EVO Enforcer 4" soon)
I'd recommend you replace those differential covers before that 4" lift so you can fill the differential up to the proper level without it spilling out (as the axles rotate with the new lift height, stock fill caps get lower). So, however that timing works for you.
Old Dec 23, 2013 | 09:03 AM
jeepherz's Avatar
Default How about both?
Another thought to confuse you- diff. cover AND slider. I have AEV covers, and diff. sliders. (AEV on the rear- can't remember the brand on the front). Mine have been used and abused. Not entirely sure I'd recommend AEV on the rear for one reason- it leaves the actual seam of the diff. cover exposed. They say they do this to accommodate different size covers-. As you can see the slider has been hit a ton on the edge where the seam is exposed- and my seam is still perfect. So it does do the job- but 1/4" more steel and I wouldn't have to worry about it. (Note to self; test fit BEFORE powder coating). There are those who think these are overkill but I'll take any protection I can get.If you have Rubi rails I'd go for covers. But if not I'd go sliders- then covers- then diff. sliders if $$ permits.Click image for larger version
ID:	518719Click image for larger version
ID:	518720Click image for larger version
Name:	Front cover.jpg
