diff covers selection
Diff covers tested in JP magazine
Stock dana cover pierced by .22 long rifle
Crane diff cover(thick cast ductile iron with painted finish) is caliber rated to a .454 Casull defeated it
Dynatrac diff cover(thick nodular cast iron with powder coat finish) is caliber rated to a .454 Casull defeated it
Fab fours( 1/4" inch steel formed and welded with zinc plating powder coated) .454 Casull defeated it, which is a magnum version of the .44
Rugged Ridge by Omix-Ada(thick cast iron with painted finish) .454 Casull defeated it
Solid axle industries(thick cast iron w/ raw finish) .454 Casull defeated it.
Extreme medal products(formed,welded, and powder coated 1/4" steel) .454 Casull defeated it
Riddler Manufacturing(Thick, ductile cast iron w/raw finish) .460 S&W defeated it.
Blue Torch Fab(Formed and welded high strenght 1/4" steel plate raw finish) 7.62 soviet defeated it
Great lake extreme offroad(formed,welded,high strenght 1/4" steel plate,1/2" ring raw finish) 7.62 soviet
Gear tech heavy duty(Extraordinarily thick nodular cast iron w painted finish) .303 British defeated it
OX offroad products(Cast,high strength steel w powder coat finish, up to one inch thick in center) .303 british
Great Lake extreme offroad up-armored version(Cast, high strength steel w powder coat finish 1/4" plate steel, 1/2" steel ring,1/2" armor strap running down center) Caliber rated bullet proof.
Caliber used to test on products and velocity of round
.22 long v-930
.45 acp v-850
.357 v-1,500
.454 casull v-1,900
.460 S&W v-2,200
7.62X39mm v-2.350
.303 British v-2,460
.450 marlin v-2,225
22-250 remington v-4,150
.22 long v-930
.45 acp v-850
.357 v-1,500
.454 casull v-1,900
.460 S&W v-2,200
7.62X39mm v-2.350
.450 marlin v-2,225
I too have heard great reviews about Crane, but haven't been able to track some down for D30/D44. The only thing I'm worried about the Riddler is the bolts being too recessed and not being able to torque them down.
And I do remember the post about diff covers rubbing on track bars. This does concern me also, but that was seen in a Solid, Dynatrac, and a Riddler diff cover.
https://www.jk-forum.com/forums/show...cover+trackbar
Hmm decisions decisions...
That's an interesting way to test a diff cover. Not sure it's real world for a diff cover, but non the less, an interesting read. I'm surprised to see the Riddler testing above the Crane. Previously, I thought that Crane was using better steel... marketing hype maybe.
Before I purchased the Riddler covers, I called and asked if they had any problems with track bars. The only track bar that they had run into problems with, was the JKS. Sounds like the FT TB has some issues also. My stock track bars do not rub at all.
Decisions... good luck, and thanks for posting that info. up.
With Solid, Dynatrac, and PSC is they have those ridges that could be rubbed on if the track bar touches and rubs on it. Something that could just be fixed with a grinder or something.
Riddler is pretty smooth faced and if the track bar does rub I fear it would make a hole from constanting contact.
