Which diff fluid?
Be been wanting to change my diff fluid but I'm not sure which kind to use. I've got Yukon 5.13 gears with the factory limited slip in the rear. I'm not sure if it makes a difference but I'm going to be doing a lot of heavy towing also. Thanks.
You shouldn't run friction modifier with synthetic lube on an LSD. If the gears don't chatter, it isn't needed.
Mobil 1 Synthetic Gear Lube LS 75W-90 contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
In my opinion - if I had an LSD, I would use the exact same stuff and friction modifier amount that the dealer uses and call it a day.. That's what it's been tested with. Anything else is a guessing game.
