difference between winch fairleads
Old Sep 11, 2009 | 04:12 AM
gpb's Avatar
gpb
Originally Posted by w squared
Not all hawse fairleads are created equal.
Some of them are thicker than others, meaning a different radius curve.
Thanks for taking the time to find pictures of two fairleads, that really helped show the difference.
Old Sep 11, 2009 | 05:00 AM
Mark Doiron's Avatar
Originally Posted by gpb
For whatever it's worth, the Warn steel roller fairlead that came with my M8000 weighs 10.7lb.
And the steel cable weighs 20 pounds (I just weighed mine), so you're looking at roughly a 25 pounds (estimating the synth cable at 5 pounds) weight savings to switch from steel/roller to synth/Hawse.
Old Sep 11, 2009 | 05:26 AM
wayoflife's Avatar
JK-Forum Founder
for whatever it's worth, i run synth line with delrin rollers on my white JK and on steel rollers on my orange JK. as mentioned, so long as the rollers are new and haven't been used with steel rope, they will be just fine to use. i personally like running rollers as they work much better in extreme side pulls. however, as mentioned, not all hawse fairleads are made the same and you can get some that are significantly thicker and that helps a lot.
Old Sep 11, 2009 | 06:40 AM
gpb's Avatar
gpb
You're looking at roughly a 25 pounds (estimating the synth cable at 5 pounds) weight savings to switch from steel/roller to synth/Hawse.
That is certainly true, and the weight of the wire rope is a factor for considering synthetic line if the other factors weren't convincing enough.
However, what I was talking about was fairlead choice with synthetic line; hawse or roller. Since both cases are with synthetic rope, the weight savings of synthetic vs. wire rope isn't a factor.
