Differential fluid
I replaced my stock differential covers and changed the fluids, cleaned out the cavity with break cleaner fluid, dried everything out replaced the fluid, drove around 2 hundred miles and check the level and have a lot of metal on the dip stick (magnetic on end) and the 75w90w mobile on looks real black again, plan is to change the fluid out again with cheap 75w 90w run it about 50 miles and check it again. any comments on this. oh yeah the first change came under 14,000 miles, along with a bit of gear slap. again good comments are welcomed
