Differential Oil? Need some help
Old Dec 29, 2008 | 12:08 PM
dlincoln91's Avatar
Default Differential Oil? Need some help
Ok so i was told to check my diffarential oil to see if it was milky from contamination. So i did and it was fine, but when i unscrewed the 3/4 bolt on the differential cover it started pouring out. I was told that it was suppossed to be level with the hole.
So what should i do
the oil was still dark grey/black
i have 12K on this oil
Old Dec 29, 2008 | 12:45 PM
Infidel616's Avatar
Were you driving it just before you unscrewed the bolt? Was the fluid at operating temp? Im pretty sure that like your oil it is a cold fill level
Old Dec 29, 2008 | 01:20 PM
dlincoln91's Avatar
it was warm but nothing like burn your hand my jeep i think i had set for like 2 or 3 hours o mayb more i dont remember
Old Dec 29, 2008 | 01:29 PM
I think you can look at WOL write up...it just gives you an excuse to change the diff oil. To the top is sufficient I think...
my factory oil was WAY more than the refill and change I put back in though. still makes me wonder if I filled enough...
Old Dec 29, 2008 | 08:51 PM
dlincoln91's Avatar
yeh thats what my friend said
he just said if i started hearing a whine to stop and get it looked at
