Disco question
so i recently removed my 2" OME lift kit due to DW issues and i left my JKS disconnects on there. I didn't even think about it until i looked at the sway bar just now. Is there a problem with running a disco meant for a 2-6" lift on a stock set up? the angle of the sway bar is probable 45 degrees now...thanks guys
ome
so the ome set up was so bad you couldnt leave it on
Make sure you have your JKS discos adjusted to the shortest length possible and it probably won't be much of an issue. I assume you'll be getting another lift anyway. You may as well keep them. Your sway bar should be completely horizontal but a little angle doesn't seem to do much. I didn't really notice much difference with the sway bar completely disconnected just running around town.
I'm surprised you had that much issue with an OME kit. That's the lift i wanted but it was too expensive and the deal on my RC was too good to pass up. |
Originally Posted by marcoseddi
(Post 1361820)
Originally Posted by ibjeepr
(Post 1361911)
