Disconnected on streets and highways
Old Aug 29, 2013 | 06:29 AM
Rploaded's Avatar
Originally Posted by kh202
I wasn't aware that swar bars were legally mandated peice of equiptment Not saying you guys are wrong, but what would their case be?
The vehicle was designed with the system "hooked up" from the factory. Altering a vehicle or using it in a manner not consistent with the factory design is negligence when a death occurs.
Why do you think the rubicon reconnects automatically? Liability for Chrysler....
In respect to lifts etc. If the lift was installed in a manner not in compliance with DOT regulations and an attorney or prosecutor wanted to raise the point.... Then yes it could end badly....unlikely but possible...
Now if you installed your lift and left parts off knowingly because it looked cool or whatever, that is pre planned negligence.....
What I'm saying here is if you do not take reasonable steps to insure the safety of those around you while driving.... You can be found guilty in the event something happens....
Old Aug 29, 2013 | 07:26 AM
Dryver's Avatar
In Ohio, the statutes specifically say that it is illegal to disconnect any part of the factory suspension. I imagine that pretty much most other states have similar statutes. We also have maximum bumper heights (and they use the frame height if you lowered your bumper). Pretty sure that some of the lifted vehicles I see running around probably exceed those numbers.
Old Aug 29, 2013 | 11:31 AM
spinlock's Avatar
Originally Posted by TyMarolf
I was lazy about a month ago and haven't connected my sway bars. 3 wheeling trips later and plenty of daily driving its pretty fun and fairly sturdy. I have an AEV 3.5 lift that seems to handle it very well.
Pro's an cons of doing this? Anyone else do this?
I had the same lift kit. By doing this, IMO you are missing out on of the best AEV features: road handling. The AEV springs are progressive so they are not rock hard during initial compression. By disconnecting the sway bars the load transfer will compress the tall springs on the outside of the turn inducing body roll. It probably doesn't feel like an early 70's Cadillac ocean-liner but it is definitely allowing more body roll therefore spoiling your road handling.
I can't comment on the formal legality of it because on the local asphalt, from lights to lifts it seems like a free-for-all, but the body roll will cause your tires to break traction sooner under lateral load, so yes there could be causality (liability) pointed to the disconnected sway bars depending on the circumstances of an accident.
Old Aug 29, 2013 | 11:47 AM
TyMarolf's Avatar
I'm totally missing out- it drove wonderfully before- ordering those jks disco's
