Disconnecting question?
I dont have front sway bar disconnects yet i have a 2.5 inch teraflex lift with a coast front driveshaft so i dont have to worry about ripping the boot!
1. dont have time to order up sway bar disconnects i am leaving tomorrow for a off road trip
2. I would like to disconnect (i dont mind unbolting the bottom of the sway bar links
3. I will be camping close to the enterence of the park
4. here is the real question! when i go to leave am I going to have a horrible time trying to get the sway bar links bolted back up? am i going to need my floor jack? I image i will be able to bolt it back up but do not want to be suprized if i can and have to drive 3 hours back home wit it disconnected that is way to dangerous!
No need to jack anything up. Just be on level ground to connect / disconnect the sway bar links from the axle. Then you will need to secure them to the frame so they're not flopping around. A bungee cord works well. Some use zip ties.
Originally Posted by Cunnart
If you are having a hard time getting a bolt back in one side have some one rock the jeep and that may help, just watch your fingers if you do that.
I usually have my three hundred pound buddy lower it all down then raise it up slowly and I can reconnect both at the same time.
Sounds good guys!!!! Thanks I guess i will just improvise if i am having troubles getting it in... ha ha ha thats what she said
I will find the biggest person i can find and ask them push down on my bumper if it comes to that!
