Disconnecting Question
Old Jan 6, 2013 | 11:32 AM
Gman*2007's Avatar
Default Disconnecting Question
When off roading do you only disconnect the front and not the rear?
Old Jan 6, 2013 | 11:37 AM
iwaxmyjimmy's Avatar
Thats what most do, I plan on experimenting with disconnecting my rear even though it is so frowned upon here and they only thing people can argue is the off camber lean to it. As long as you adjust your driving for it you should be fine. IE pick a different line, smooth throttle and brake inputs. There are plenty of more top heavy vehicles without sway bars.
Old Jan 6, 2013 | 11:44 AM
gunbo75's Avatar
For me i just disco the front where I go it could cause a rollover situation just my thinking though.
Old Jan 6, 2013 | 11:49 AM
Gman*2007's Avatar
Thanks guys. I've got a 2012JKU and have ordered a set of TeraFlex disco's and was wondering why they didn't offer them for the rear.
Old Jan 6, 2013 | 02:02 PM
Mschneid's Avatar
You can disconnect the rear but that would be for serious rock crawling. In most cases the front is fine. The rear is a lot thinner which will give plenty of flex. If you do disco the rear double and triple check brake lines, brake cable, and electrical lines are long enough!
Old Jan 6, 2013 | 02:30 PM
zstairlessone's Avatar
Don't run sideways on a hill or use much speed (specially round turns) with no front or rear anti-roll bar hooked up. Be careful when Jeep is leaning on the same side over stout rocks and ridges too.
Old Jan 6, 2013 | 05:17 PM
Smashboogie 4x4's Avatar
Former Vendor
We don't run sway bars at all. You just need to realize you don't have sway bars and adjust your driving. It is 100% better to wheel with no sway bars at all when on the rocks. It is actually better to use sway bars when in mud though.
Old Jan 6, 2013 | 08:15 PM
MangoWilly's Avatar
I ran 33's all last year, no bumpstops and always had the rear disconnected. Had no issues with brake lines or anything. I constantly look under my jeep to see how things look. Now I have brake line extensions, bumpstops and am running 35's. I will still four wheel with both disconnected.
