Disconnects?
Old Feb 6, 2009 | 12:43 PM
stevedolce's Avatar
Default Disconnects?
There's a set from TeraFlex for about 120 bucks & a set from JKS for about 150 bucks..is there a real difference?
They seem rather straight forward and easy to install..
Any advice??
Thanks
Steve
Old Feb 6, 2009 | 12:45 PM
armycop's Avatar
I had the Teraflex ones and they worked great. They have a pin that stores them in the up position.
Old Feb 6, 2009 | 12:56 PM
wayoflife's Avatar
JK-Forum Founder
Any advice??
Thanks
Steve
the TF discos are affordable and they work well. the JKS discos are adjustable and are beefier.
Old Feb 6, 2009 | 01:03 PM
Jharkins26's Avatar
Default disco
check out RC's They are easy to use. . .
Old Feb 6, 2009 | 04:15 PM
JeepinMass's Avatar
IMO the advantage of TF is the pin that holds the sway bar in the disconnected position. The JKS are also a nice piece but you have to zip tie or tie wrap the sway bar once disconnected. I've ordered the TF.
Old Feb 6, 2009 | 04:17 PM
fftri's Avatar
Ditto on the TeraFlex w/ the stowage pin.
One less thing to worry about and simple to disconnect and stow.
Old Feb 13, 2009 | 07:45 PM
kurtfriedrich's Avatar
Default JKS "Quicker" Disconnects - zip ties aren't enough
I have the JKS "Quicker" Disconnects, and I got the really big wide zip-ties, and at least 1/2 the times I go wheelin, the zip ties are getting broken. I am looking for a better solution to keep the sway bar from moving. The zip tie isn't cutting it.
I am running Wrangler 285/75R-16 MT/R on Unique 16x8 12cm backspacing. Those tires are more like 11" rather than the 12"s many people run, so I have lots of clearance and they never rub.
Thanks
Kurt
