Do have and ORE hand throttle installed on your JK?
Not to sound negative at all, but I would go find a few fun SAFE places to play in 4lo someplace and work on going over some single rocks without touching your clutch at all. Your clutch and drivetrain will thank you for it after you master that skill. It is also much much safer to not disengage your drivetrain when crawling around like that. You can start your jeep in 4lo without the clutch in then just leave it in first in 4lo and crawl nice and slow over anything you toss at it. Feathering the clutch is just going to melt your friction surface of your clutch very fast if you do that. Your jeep may at times sound like it is going to stall but the electronic throttle will kick in and knock your idle speed up to prevent that from happening as long as you DONT touch your clutch. Good luck with the practice, let us know how it goes.
I did not know about the idle kicking in when engine sounds like it is going to die. I will try that. My plan this summer was to hit the hills close to me where I can practice without going over and edge or overturning my Jeep. It was suggested to me to try a hand throttle, but if it is not needed, then I will not worry about it.
Thanks for the advice.
Try this in a flat parking lot first then on an incline.
Set the hand brake then push the button in with your thumb but don't release it. Continue applying upward pressure while you use your left foot on the clutch and your right on the gas. As you let the clutch out as normal you will feel the Jeep pull at the break. Get a feel for this and you can allow forward progress to begin by slowly releasing the handbrake in a controlled way. On an incline you should be able to hold the Jeep from rolling while you operate the clutch and gas with your feet.
Go practice then try it on the trail!
While I can see why you might think that, go practice this....
Thanks for all the help. I am going to wait a bit to intall this, but I am sure it will be coming one day.
