Do I need to drop the axle fully to check for spring problems?
I have been having this squeeking issue that I am going to work vigorously on ruling out the problem tomorrow.
Do I need to basically undue my entire lift to drop the springs? (minus control arms)
I put my head in the wheel between tire and fender and I am just not sure...
I laid underneath, even harder to pinpoint.
It is obvious creaking/squeaking from all 4 tires. Sounds like metal creaking not so much a rubber squeak. It happens with the slightest movement of the vehicle. even an inch.
My plan for tomorrow was first disco the swaybar, see if that rules anything out.
Then loosen all the control arms (i have a snapping noise to find as well but it is a rare occurance)
Then move on to the shocks and springs.
Well I am pretty sure they were/are. But my torque wrench may of been off a bit so I got a new one now, and im gonna retorque every last thing even the lug nuts.
As I was explaining my issue with the creaking to the tech at rock krawler, I realized my huge error...
Thankfully I have not wheeled yet and he said it probably wouldn't cause damage anyway.
My stupid self had the trackbar backwards in the front... The articulating end was at the top instead of the axle.
