Do I need new Shocks and Springs???
Old Nov 11, 2012 | 03:42 PM
ShiftKnowledge's Avatar
Default Do I need new Shocks and Springs???
I have a 4DR 2007 X with the el cheapo OEM shocks. Its bumpy as heck and I just rode in a 2013 Rubicon - huge difference. My shocks aren't even gas powered and my guess is they are shot. Money is also a problem because I don't have much of it. I found a deal on CL for a set of almost new Rubi (red) shocks only 11 miles on them for $70. My question is
1. Will this make a big improvement?
2. Do I need the Rubi springs too?
3. Can I do all of this my self on the street in front of my apt with minimal tools?
Thanks for looking.
Old Nov 11, 2012 | 03:57 PM
el mono's Avatar
Get the shocks; they will make a difference and you can install them yourself with wrenches and sockets (check the Project-JK write-ups). The springs won't make a difference unless they're higher-rated springs (based on the last two numbers in the part number, I believe). But swapping springs is much more labor/tool intensive. Good luck!
Old Nov 11, 2012 | 03:59 PM
Robar's Avatar
If your shocks are shot the Rubi shocks should be an improvement, you won't need Rubi springs unless you just want them, and you just need a couple of metric wrenches complete the swap. Having gear wrenches will help a lot with the front top nut.
Old Nov 11, 2012 | 04:22 PM
catahoula's Avatar
Thanks for looking.
1. Yes.
2. Unless you want to get any additional lift. Check the last two digits on springs and compare to see it it would make a difference. i replaced my springs and shocks on my 2 dr for a 4 dr. Springs went from 14/55's to 18/59's. Gained around 1.5 - 1.75". Might be slightly different with a 4 dr to a 4 dr.
3. Yes very easy with the right tools. Took me and a buddy 3 - 4 hours replacings springs, shocks, and installing spacers.
Old Nov 11, 2012 | 05:10 PM
Cool thanks for all of the suggestions. I'll just do the shocks for now and see how that goes. My cousin might have a jack I can borrow to make the process faster. My fenders/bumpers are really faded so now I just need to figure out how to paint them so they will have a new look. I'm looking at plasti dip and truck bed coating as a solution.
Old Nov 11, 2012 | 06:53 PM
big dr's Avatar
Shift,,,, i am in the process of building my 2012. I am just south of you in Huntington Beach. if you want my stock fender flares, shocks, bumpers,,, make an offer! I heard $70 earlier in the thread. You can have them all for that!
Old Nov 11, 2012 | 06:59 PM
SMA334's Avatar
I have stock shocks and springs off of a 4door Rubicon. Sitting in my garage. Come get them
Old Nov 11, 2012 | 07:38 PM
Freewill's Avatar
If you can get hold of fresh springs with high numbers and a set of rubi shocks, go for it. Well worth the effort unless you want to go the serious lift route.
