Do i need a steering stabalizer?
Old Aug 13, 2010 | 06:23 AM
JSavage's Avatar
Default Do i need a steering stabalizer?
I put a 2.5' BB on my jeep and 35's. I have had it balanced and aligned. They can't adjust the caster because it is stock so it is way out. I know I need to get new control arms but don't have the money. It still drives weird. Would a steering stabilizer help until I can get the monet together to get the control arms? Just windering the cheapest way to fix this. Thanks.
Old Aug 13, 2010 | 06:30 AM
JSavage's Avatar
It seems to pull back and forth at different times. I live in the country and the roads aren't the greatest but it sometimes seems hard to control. You can take the steering wheel and move it right and left and there is a lot of play in it. Just thought a stabilizer would take that out and feel a little more responsive.
Old Aug 13, 2010 | 06:36 AM
JSavage's Avatar
When I put the tires on they had 46 in them. I dropped them down to 30 and it made a huge difference. Should I go lower?
Old Aug 13, 2010 | 06:38 AM
jfreeddo's Avatar
[QUOTE=JSavage;1805712 Just thought a stabilizer would take that out and feel a little more responsive.[/QUOTE]
unless you removed the stock one, you already have a stabilizer.
Old Aug 13, 2010 | 06:39 AM
rinkishJK's Avatar
mine does this as well. its due to low caster. mine is roughly 3.5 if i remember. u can do like planman said and toe in a lil, but not to much or u will mess up the tires. i would save some $$ n get some lca's! a SS is not gonna do anything. mine drives exactly the same with the SS on or off.
i run 30 psi.
Old Aug 13, 2010 | 06:44 AM
JSavage's Avatar
I think the cheapest I have found the control arms is about $200. Is that about right? Anything I should stay away from? My caster is like 2.7" if I remember. Well below where is should be. The did the toe in and got it back to spec. I know I have a steering stabilizer already but I know when I had my YJ it felt similiar and the new steering stabilizer seemed to make a huge difference.
Old Aug 13, 2010 | 06:46 AM
JSavage's Avatar
Do I need front and rear control arms or just front?
Old Aug 13, 2010 | 08:00 AM
rinkishJK's Avatar
for caster u just need either front uppers, or lowers. i would spend the extra $$ n get lowers. there easier to install also.
Old Aug 13, 2010 | 08:16 AM
JSavage's Avatar
Rough country has the lowers for $179.00 Is that a good price? Anybody used them before. That is the company I got my lift from as well.
Old Aug 13, 2010 | 08:26 AM
Rub61's Avatar
Good question.
Anybody out there running the Rough Country lower C/A's?? Any opinions on these?
