do i need a track bar??
Old Sep 20, 2010 | 05:22 PM
stevedolce's Avatar
Default do i need a track bar??
after installing my new OME springs, i decided measure my axel offset.
measuring from the spring tower to the outside lug of my tire:
front driver 13.75
front passenger 13.25
difference of 1/2 inch
rear driver 13.75
rear passenger 13.50
difference of 1/4 inch
i'm running a the TF Track bar relo bracket in the rear, stock track bar in front.
do i need something for such small amount? or spend the money on other stuff?
steve
Old Sep 20, 2010 | 06:28 PM
Pluke the 2's Avatar
i believe you divide that 1/2" in half and that 1/4" in half and that doesn't seem to bad.
i know both of mine are like 1" each and it tracks pretty straight.
Old Sep 20, 2010 | 07:08 PM
funwthmud's Avatar
the difference may not seem like much, but you will be putting constant sideways stress on your control arms. which may cause premature wear on the bolt holes. Just make sure you keep everything torqued to prevent wear.
Old Sep 21, 2010 | 07:08 AM
cthompson's Avatar
You should probably get one but I dont think you need to get in a big hurry over it.
Old Sep 21, 2010 | 07:10 AM
wayoflife's Avatar
JK-Forum Founder
totally not necessary to get but, if you can afford it, being able to recenter your axle is nice.
