Do I need Wheel Spacers?
Old Feb 14, 2011 | 09:22 AM
Spartangreen's Avatar
Default Do I need Wheel Spacers?
I need to know if I need wheel spacers.
08' Sahara Stock 18" rims.
The Teraflex 2.5" Coil lift w/ new shocks.
I am planning to get 275/70/18 GY Duratrac's.
The shop that did the lift said with the coil lift spacers are not needed. I thought they were.
Thanks
Old Feb 14, 2011 | 09:25 AM
wayoflife's Avatar
JK-Forum Founder
no, they aren't "needed" but, i would recommend them as without them, the sidewalls of your rear tires will sit really really close to the sway bar link bolts if not touch them. yes, you can mount the links on the inside of the sway bar but, i think the spacers are the better way to go.
Old Feb 14, 2011 | 09:41 AM
Yes, the shop installed the links on the inside of the sway bar for this reason.
Old Feb 14, 2011 | 10:01 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Is there one that is better than the others and how much spacing would be required
for stock 18" rims with no lift?
Old Feb 14, 2011 | 10:05 AM
wayoflife's Avatar
JK-Forum Founder
at one time or another, i have used spidertrax spacers on all my jeeps and they have always worked without any problems. for a jk, i would recommend the 1.5" spacers.
Old Feb 14, 2011 | 10:13 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Thanks
Coil spacers won't be needed but some 1.25" wheel spacers will be needed.
Old Feb 14, 2011 | 10:18 AM
donnie's Avatar
Thanks Eddie.
Looks like Im going to be letting my fingers do the shopping.again
Old Feb 14, 2011 | 10:21 AM
That's what I meant wheel spacers. Are wheel spacers needed.
I'm seeing conflicting information.
Old Feb 14, 2011 | 10:24 AM
TeraFlex's Avatar
Yes wheel spacers are needed with stock wheels to allow clearance between the rear swaybar/swaybar links and the back of wheel/tire.
Old Feb 14, 2011 | 10:40 AM
Thank You!
