Do you have an answer for this?
Old Mar 18, 2009 | 02:51 PM
NTXJK's Avatar
Default Do you have an answer for this?
I was chopping my bumper today and noticed the bushing on the lower part of the pro comp trac bar was coming out has anyone else had a similar prob, the only thing I can think of is the backside of the mounting bracket has a part cut out that drops in a angle causing the rubber bushing to pop out should I run a diff trac bar
Old Mar 18, 2009 | 03:59 PM
PeeJ_Zip's Avatar
I can see the problem. It looks like the inner sleeve is to short. That would put the pressure on the rubber instead of the metal sleeve. I have seen this before.
Old Mar 18, 2009 | 04:22 PM
NTXJK's Avatar
I just looked at that you got a point
