Do You Really Need Grade 8, 9/16", Fine Thread, Partially Threaded Replacement Bolts?
Old Oct 16, 2014 | 07:10 PM
planman's Avatar
Forum Tech Advisor
Default Do You Really Need Grade 8, 9/16", Fine Thread, Partially Threaded Replacement Bolts?
If you have properly maintained your jeep and/or will continue to do so in the future, the answer is "no, you do not need them."
The stock, smaller-than-bracket-bolt-hole-and-bushing-sleeve bolts only become a problem when insufficiently torqued because the smaller size permits more violent oscillations within the bracket and bushings. This results in more violent oscillations commonly referred to as Death Wobble, and the extra play results in greater damage to brackets, bushings, welds, and other components.
Again, the undersized stock bolts are only a problem when they are not sufficiently torqued and maintained--the greater play when not sufficiently torqued is the common source of Death Wobble.
The bolts themselves are not a source of Death Wobble.
Now, many people who have done the swap have experienced improvement in tightness and handling of their front end and suspension. For some, they experienced Death Wobble before the swap, and it went away after the swap.
People who have experienced improvement from the swap to 9/16" Grade 8, partially threaded, fine thread bolts, had this experience because of the byproducts of the swap.
These byproducts may include one or more of:
  • the swap resulted in greater attention to torque and maintenance
  • the swap resulted in the owner purchasing a quality and calibrated torque wrench, learning how to properly use it, and becoming more familiar with how their jeep works
  • fine thread, partially threaded bolts stretch slightly less than the stock bolts, and as a result, they hold torque better (but this still does not negate the need for maintenance)
  • the swap resulted in pre-loaded/binding/twisted rubber bushings returning to a neutral position between the brackets at ride height (for people who did/had incorrect installs where bolts were not loosened for the installs)
  • for people who had not sufficiently maintained their jeep with stock bolts and bracket holes were egged out, the larger bolts helped center the bushing bolt sleeves over the holes for a more even clamping of that bushing bolt/crush sleeve force between the brackets
For people who properly maintain their jeep, don't have egged/wallowed bracket holes, and who don't have pre-loaded rubber bushings, the byproducts of the bolt swap don't really matter, and they do not experience any real difference from the swap.
But, what about using partially threaded bolts instead of fully threaded bolts in brackets and bolt sleeves?
Well, it doesn't matter if bushing bolt sleeves get scored by stock bolts. The scoring is only a concern if it is the result of looseness from lack of torque/clamping force. None of the joints or bushings corresponding to the bolts that are swapped are supposed to have the sleeves rotate on the axis of the bolts. The bolt sleees are to remain static between the brackets, and the suspension articulation is allowed by either the twisting of the rubber bushing, or the rotation of a joint.
The clamping force of 125 ft lbs of a stock bolt, with the bushing bolt sleeves set at a full and even contact surface on the inside of the bracket, is sufficient to prevent movement within the brackets.
If the contact surface inside the bracket is damaged, if the contact surface is uneven because the holes have been egged/ovaled out, etc., then the stock bolts may not be sufficient to center the bolt sleeve over the bracket holes.
A larger diameter bolt may be needed to center the bolt sleeve/bushing over the hole in order to get an even surface inside the bracket.
If the holes are severely egged out, the larger diameter bolt may be insufficient, and either washers or plate may need to be welded to the bracket to provide an even surface for the bolts, washers, and bushing bolt sleeves to hold the clamping force sufficient to prevent movement at 125 ft lbs.
Now, that being said, I still suggest that people consider doing the swap of at least the front trackbar bolts. Why? Because the cost is relatively small, and the byproducts can be helpful. But, it is more out of preference than a requirement.
Should you spend the equivalent of about 1/2 tank of gas and spend $40 to do a swap all of your front and your rear track bar bolts, and all of your lower control arm bolts?
Well, if you think that the byproducts of the swap are worth it, then go for it. Most of us waste $40 on things, recreation or entertainment of less value--on a regular basis.
Many of us change our engine oil more frequently than is needed and easily overspend $40+ more annually on oil and filters. So, what? It's a preference. It is a "conspiracy" by the oil companies and lube centers to tell us that we need to change our oil every 3k miles or 3 months instead of at the intervals recommended by the manufacturer in our owners manuals? Is it a "conspiracy" that some recommend synthetic oil? Maybe. Who cares? Some people with an axe to grind, maybe care. For the rest of us, it is a choice and a preference. Northridge4x4 and Synergy selling bolt kits is no conspiracy.
Remember, swapping just the front trackbar bolts might cost you $6, plus or minus. They will hold torque better. The front trackbar bolts are the most critical with relation to steering and front end wobbles.
I wanted to post this thread to clarify my posts in my Diganosing Death Wobble threads.
In those threads, I wrote (emphasis added):
Originally Posted by planman
I'll start out by explaining that Chrysler decided to use a 14 mm trackbar bolt, with a trackbar bushing sleeve designed for a 9/16" bolt, and the trackbar bracket bolt holes are somewhere around 15-16 mm large. This is a sure recipe for DW if the trackbar bolts are not properly torqued and periodically re-torqued to 125 ft. lbs.
I swapped the trackbar bolts in our 3 JKs long before Northridge4x4 introduced their 9/16" bolt kit or before Synergy started selling volumes of their kit. Northridge4x4 sent me 3 full bolt kits to swap into our 3 JKs--at no charge. I've spent thousands upon thousands of dollars with Northridge4x4 and referred hoards of customers to them. I have recently discovered that there are a few unnamed bullies on another forum who actually are upset that Northridge4x4 sent me bolt kits for my 3 JKs (outfitted with purchases from Northridge4x4), and they are upset that Northridge4x4 referenced the video I had already made about swapping the front trackbar bolts. Really? Northridge4x4 threw in free bolt kits for people who purchased suspension kits from them for a long time after their introduction. Some people just need to grow up, "shut up and wheel," and stop acting like schoolyard bullies.
The smaller stock bolts are less of a design flaw than the failure of Chrysler to include torquing suspension bolts as part of a new car Pre-Delivery Inspection at the dealership, and to include torquing at least the front trackbar bolts at every oil change interval or two as part of normal maintenance.
Bolts stretch, metal fatigues, and suspension cycling/vibrations results in bolts losing torque. This is a bad combination with the 14 mm bolts in an up to 15+mm stock bracket hole and trackbar bushing bolt sleeve.
So, do you absolutely need to swap your bolts to 9/16"? No.
Should you do the swap? If you want the byproducts of the swap, and/or have some damage from egged/ovaled holes, then you probably should where the problem exists. If you want the peace of mind knowing that your front trackbar bolts will hold torque better and provide a snugger fit, then it is worth swapping the trackbar bolts.
Old Oct 16, 2014 | 07:32 PM
LidLess07X's Avatar
The time and energy to make this post speaks volumes. Thank you for what you bring to the JK community.
Old Oct 17, 2014 | 06:22 AM
Saharaunlmtd's Avatar
Thanks for posting. This was very informational.
Old Oct 17, 2014 | 06:28 AM
jnabird333's Avatar
I will happily take anyones bolts that they remove....
Old Oct 17, 2014 | 06:44 AM
kjeeper10's Avatar
Vet Army
I have a box somewhere
2007 Rubicon /2 door/6 speed
Old Oct 17, 2014 | 10:26 AM
planman's Avatar
Forum Tech Advisor
What are you going to do with about 100,000 stock bolts?
Old Oct 17, 2014 | 11:13 AM
jadmt's Avatar
JK-Forum Ambassador
melt them down and make a statue of a bolt only bigger lol.
Old Oct 17, 2014 | 12:02 PM
jnabird333's Avatar
Use them as they were originally intended... I have never seen a stock bolt break or fail (not saying it hasn't or can't happen) but I have seen replacement bolts fail. The stock bolts have a higher tensile strength than a standard Grade 8.
I am not making lite of the original post. I think it is good info, but I think this issue is overplayed and is mostly a mechanism to sell bolts.
As the OP mentioned properly torqued and maintained and bolts are fine, the issue is when they were or are not... Changing bolts is a solution to a symptom not the problem.
Old Oct 17, 2014 | 04:53 PM
Morbo's Avatar
I think changing the bolts, does very little to the problem. The trackbar bushig hole is 9/16, that´s ok but the bracket on the axle is way bigger (at least on my jeep it is). The best solution is to weld some thick washers to the axle´s braquet only then you can eliminate all freeplay.
Old Oct 17, 2014 | 05:59 PM
planman's Avatar
Forum Tech Advisor
When the bolts are torqued to 125 ft lbs and the bushing bolt sleeve is centered over the bracket bolt holes for an even surface contact, the clamping force of the bolt and friction of the bolt sleeve in the bracket is sufficient to prevent movement.
If anything, a larger diameter bolt helps center the bushing bolt sleeve in the bracket.
If washers are welded on off center, it can interfere with things.
The best designed washers I've seen to fix ovaled/wallowed holes are these:
http://www.ruffstuffspecialties.com/catalog/FIXIT.html
