Doable on stock tire carrier?
Old Apr 26, 2014 | 03:10 AM
ichirubi's Avatar
Default Doable on stock tire carrier?
Hello everyone. I have a love for the factory '13 jkur stock rims. Is it doable to mount a 315 duratrac on factory '13 jkur rims to the stock tire carrier? Will spacers be needed and what size if necessary? Photos will help. Have a great weekend.
Old Apr 26, 2014 | 04:38 AM
A'sJK's Avatar
I saw a guy do this with a 1.5 wheel spacer. Im not certain but I think it was a 315 tire. Without the spacer Im fairly certain it wont fit. Just make sure you modify the two tire rubber bumpers as well until you can reinforce the hinges.
Old Apr 26, 2014 | 07:34 AM
suprablaski's Avatar
Most important thing with using the stock carrier is that you have solid contact with the rubber bumps, if not the tire wi bounce around and tear up your carrier and prolly your tailgate
Old Apr 26, 2014 | 07:54 AM
idiotec's Avatar
My 35 on stock wheel would not fit without an adapter. I used the expedition one adapter. I then had to get the daystar bump extensions to get solid contact.
With that mine is solid and works well.
