Does an adjustable trackbar still need a relocation bracket
Old Oct 21, 2009 | 09:57 AM
JeepyJeep's Avatar
Default Does an adjustable trackbar still need a relocation bracket
Unless my eyes deceive me, I believe I have seen differing views on this. So the questions stands...does an adjustable trackbar still need a relocation bracket to correct suspension geometry?
For example, I have an adjustable rear trackbar on a Jeep with @ 5 in. lift, do I still need to elevate the trackbar at the axle, or conversely drop the trackbar at the frame, to correct geometry?
Old Oct 21, 2009 | 10:02 AM
wayoflife's Avatar
JK-Forum Founder
depending on how much lift you have, yes, i would install a relocation bracket in addition to an adjustable trackbar. at 2"-3", no, it's not really necessary but once you start getting to 4" and more, the relocation bracket will help correct the geometry. however, it is IMPORTANT that up front you install a dropped pitman arm or flip the drag link at the same time.
Old Oct 21, 2009 | 10:20 AM
jkerr's Avatar
I just had this discussion with TeraFlex. I lifted 2.5" and do not need the relocation bracket. The rear adjustable trackbar is installed and working fine. It does, however, require that you extend the ball joint further out of the trackbar than you would if you used the relocation bracket. A larger lift would require the bracket because the screw-end connector on the ball joint is not long enough.
Old Oct 21, 2009 | 10:21 AM
aBē's Avatar
So you are saying that if I have a 4inch lift I have to install a dropped pitman? can you explain it to me ?
I have this same question... and other guys said that I should remove the relocation bracket because now I have a front Adj. trackbar... so remove the relocation bracket or not?
Old Oct 21, 2009 | 10:25 AM
wayoflife's Avatar
JK-Forum Founder
you'll forgive me but this information is not entirely correct. even if the joint had enough thread to extend it long enough, you should still install relocation brackets (and address your draglink up front) IF you are lifting your jeep 4" or more. at this height, the angle of your trackbar and draglink will be pretty steep and among other things, this will effect the handling of your your jeep. idealy, you want your trackbars as parallel to your axle as possible just like stock and your drag link NEEDS to be parallel to your front track bar as well.
Old Oct 21, 2009 | 10:26 AM
Locklain's Avatar
The pitman arm will help level the drag link. The more you lift the larger the angle of the drag link which in turn translates bumps directly into your steering wheel.
Old Oct 21, 2009 | 10:29 AM
wayoflife's Avatar
JK-Forum Founder
while it's not required, installing a track bar relocation bracket AND dropped pitman arm OR drag link flip kit will help improve the handling of your jeep if you have 4" of lift or more. you would ONLY install a dropped pitman arm or drag link flip kit IF you are relocating your track bar bracket. to do one without the other would cause all kinds of problems.
needless to say, IF you have a front track bar relocation bracket installed now and DO NOT have a dropped pitman arm or drag link flip kit installed as well, yes, you should remove the relocation bracket.
Old Oct 21, 2009 | 10:42 AM
aBē's Avatar
Ok... here's what I understand in a few words, correct me if I'm wrong
4inch lift + Trackbar Relocation Bracket + Stock Trackbar = You'll need drop pitman or drag link flip kit
4inch lift + Stock Trackbar Bracket + Adj. Trackbar = No need for pitman and/or draglink flip kit
Am I right??
In conclusion (If I'm right) I DO NOT NEED a drop pitman
Old Oct 21, 2009 | 10:45 AM
wayoflife's Avatar
JK-Forum Founder
4inch lift + Trackbar Relocation Bracket = You'll need drop pitman or drag link flip kit
Am I right??
yes. a track bar relocation bracket up front requires that you install a dropped pitman arm or flip the draglink at the same time. it is the only way you can keep the two parallel to each other and that is required.
Old Oct 21, 2009 | 10:47 AM
JeepyJeep's Avatar
OK so it's off to find a relo bracket and and axle bracket brace to shore things up...
