does anyone have issue cuz heavy mod?
Old Aug 24, 2012 | 08:13 PM
tkkim's Avatar
Default does anyone have issue cuz heavy mod?
I know it is over worry..
but after add rk 2.5 stock mod kit , aev saverge wheel ,and 285 75 r17 nitto trail grappler, I'm kinda feel loss of power and worry about stress on parts.
my 12 jku sahara has 3.21 gear ratio.
does any one know heavy tire and wheel cause problem ?
Old Aug 24, 2012 | 08:22 PM
highwayman's Avatar
Yes a heavy wheel and tire combo puts more stress on all parts associated with being attached or moving them.
Balljoints, bent housings, bent/broke axleshafts are usually the first casualties.
Old Aug 24, 2012 | 08:48 PM
tkkim's Avatar
is that happened a lot ?
all of jeep owner who has aftermarrket wheel and heavy tire, get above problem?
how often ?
Old Aug 24, 2012 | 09:23 PM
Freewill's Avatar
Highwayman is correct, but your tires are not extremely large, and your lift is not extremely high. The extra wear and tear will happen, but the worn parts will not show up right away.
Bigger tires do make the Jeep feel sluggish with 3.21 gears, but that will not hurt anything very much.
Old Aug 25, 2012 | 05:26 AM
swaite3's Avatar
Dyno Run - Effects of wheel/tire weights on wheel horsepower | Flickr - Photo Sharing!
Check out the link above, this has a great Dyno run show the loss of rear wheel hp with the addition of unsprung weight.
This is a 2012 camaro but the principal is the same for our jeeps
1. (Blue curve) Factory wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 68 lbs combined per rear wheel. – Max hp: 371 hp, Max Torque: 375 ftlbs - (Baseline)
2. (Red curve) Aftermarket wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 72 lbs combined per rear wheel – Max hp: 369 hp, Max Torque: 373 ftlbs - (A [-] loss of 2 hp and 2 ftlbs)
3. (Green curve) HRE wheels: 20”x11.0” with Nitto 315/35-20 tires weighing 60 lbs combined per rear wheel – Max hp: 380hp, Max Torque: 384 ftlbs - (A [+] gain of 8 hp and 9 ftlbs and that is running a 2” wider wheel/tire combo)
Old Aug 25, 2012 | 08:20 AM
Ang3L's Avatar
There are threads about gussets, etc. that serve to beef up your axles. Do a search and you will find what you need to do in order to feel safe about your weight. Also, the main thing that will cause breaks in your axles is your rotating mass - namely your wheel/tires. Things like bumpers will not cause that much additional stress, as they are not rotating.
Old Aug 25, 2012 | 10:56 AM
tkkim's Avatar
So if i have a plan to change my gear ratio to 4.83 something, do i have to add c gusset or axel sleeve after install new gear?
Old Aug 25, 2012 | 11:17 AM
swaite3's Avatar
No you do not need to add anything. The d44 d30 combo will handle up to a 35 tire just fine for most wheeling without any issues or gussets
