Does this geometry look correct?
Old Dec 15, 2011 | 07:04 PM
BuckLisa's Avatar
Wondering if the springs need to be turned more on the wedges and shorten the LCAs ?
Old Dec 16, 2011 | 02:58 AM
Gossamer's Avatar
Originally Posted by sneck
what shocks are those? look cool
Sneck - They are the Rock Krawler 2.0 Emulsion Shocks.
Rick
Old Dec 16, 2011 | 04:23 AM
rinkishJK's Avatar
i had this issue on mine. i ended up getting the jks adjustable spring perches. the problem comes from how they weld the stock perches on the tube. once u raise the pinion to fix the angle u get this problem. teraflex and some others make new weld on perches also.
also RK has u move the rear swaybar mounts back 1". thats what we did when we installed my friends 3.5 RK lift. its in there instructions.
Old Dec 16, 2011 | 04:30 AM
Gossamer's Avatar
Ah! Maybe that is why. I started with the 2.5" kit and then upgraded to the 3.5". Ill have to check the instructions for the 3.5" to make sure I didn't miss anything else.
Thanks!
Rick.
Old Dec 16, 2011 | 05:05 AM
Gossamer's Avatar
Originally Posted by mpkelley20
I was getting worried until thie last couple of posts. I'm doing the 3.5" Xfactor in a few weeks and want the install to go smoothly. I am hoping once its installed, there will be minimal to no needed adjustaments. Hearing that you hadn't gone with the exact lift I did so you hadn;t moved the axle back makes some sense to my limited knoweledge about this stuff!
Yep, I started with the 2.5" kit and then went to the 3.5. I essentially have everything that makes the 3.5" X-Factor kit (With the exception of the rear track bar). Last night I adjusted my arms for the X-Factor length and that is where I ran into these issues. I just looked through the installation instructions again and don't see any mention of moving the rear sway bar back, but it definitely makes sense. Appears that 3/8" self tapping bolts are needed.
Rick.
Old Dec 16, 2011 | 05:29 AM
Bronco88's Avatar
Originally Posted by MOKOS
Pretty sure your axle is too far back. I'm betting you'll hit your track bar mount when u flex. Bring axle forward a bit just enough to clear your bump stop and the bump stop mount on your axle and your springs will bow less and more of your bumpstop will hit and sway bar links will clear. I just went through this...
I had the exact same problem, especially on full flex. I had to move my axle more forward and could not use the measurements that RK gives. I also could not use the RK bump stops and went to the teraflex bump stops that are open on one end to clear the track bar mount better. Mine is still not perfect but it somewhat clears most of the other stuff like exhaust… I was going to look at the adjustable spring perches but not sure on that yet, I may be able to take some pics over the weekend if this does not make sense..
Old Dec 16, 2011 | 05:53 AM
Bronco88's Avatar
Rick.
I did move the sway bar back also, 3/8" self tappers is what you need...
Old Dec 16, 2011 | 07:58 AM
Rock Krawler Suspension's Avatar
Former Vendor
Thanks for the link. I think we figured out most of your troubles via all the PM's. But, like the one person mentioned, you do need to move that sway bar back as well!...
RK
Old Dec 16, 2011 | 08:12 AM
Gossamer's Avatar
RK
Yep! I think so too, now, to find 3/8 self tapping screws/bolts.
Rick
Old Dec 16, 2011 | 09:21 AM
rinkishJK's Avatar
This is mine after the adjustable spring perch install to get springs straight.
