Does re calibrating change the tac as well as the odometer ?
Old May 11, 2014 | 02:46 PM
Kenny B's Avatar
Default Does re calibrating change the tac as well as the odometer ?
I went from 32" to 33" and I know it affected the odometer but not sure if it changes the tac.
I am changing gears and will re calibrate it once the gears are in.
Thanks.....Ken
Old May 11, 2014 | 02:56 PM
jeeparmstrong's Avatar
no you need a programmer when you change the gears and tires to recalibrate the speedo but it does not affect the tach as that's just engine speed
Old May 11, 2014 | 03:10 PM
kh202's Avatar
If you have a manual transmission I really wouldn't bother recalibrating for 32 to 33's. Heck I didn't for 32 to 35's
Old May 11, 2014 | 03:27 PM
crusaderJK's Avatar
To simply answer your question - Yes, it does affect both, odometer and tachymeter.
Old May 11, 2014 | 03:32 PM
kh202's Avatar
speedometer and odometer yes, tachometer No
Old May 11, 2014 | 03:35 PM
crusaderJK's Avatar
Sorry, I'm a bit confused. Isn't a tachymeter and a speedo the same??
Old May 11, 2014 | 03:40 PM
kh202's Avatar
Nope. Tach is the engine rpms, speedo is speed, and odometer is total mileage
Old May 11, 2014 | 03:47 PM
crusaderJK's Avatar
Alright, thanks!! Learned something new.
Foreign languages can be tricky. In german the speedo is called "tacho".
Old May 11, 2014 | 03:50 PM
kh202's Avatar
Alright, thanks!! Learned something new. Foreign languages can be tricky. In german the speedo is called "tacho".
Interesting
Old May 11, 2014 | 03:57 PM
crusaderJK's Avatar
Interesting
Yeah, well.....they basically do the same thing - measuring speed
