Does regearing void the lifetime warranty?
Old Apr 24, 2008 | 12:48 PM
VAGentleman's Avatar
Default Does regearing void the lifetime warranty?
I have heard both yes and no. Someone please clarify this for me. Thanks
Old Apr 24, 2008 | 12:49 PM
saltman's Avatar
try the search feature. this has been covered maybe 10 million times.
Old Apr 24, 2008 | 12:53 PM
Blue's Avatar
It would void the warranty on the diffs. If Crappler determined it was the cause of another failure such as the tcase, they may refuse to repair the tcase under warranty for example. It would come down to cause and effect.
You are not going to get anything clarified in this thread. If you asked 10 dealers this question, you will get 9 answers.
Old Apr 24, 2008 | 01:03 PM
Planman, What gear ratio are you running. I will have the same lift and same size tire in a matter of weeks. I have 4:10's
Old Apr 24, 2008 | 04:15 PM
cibach's Avatar
what RPM's are you running at 70?? I am thinking about 5.13's and 35"s
Old Apr 24, 2008 | 05:01 PM
RedneckJeep's Avatar
Yes. If you do not recalibrate your speedometer, you ENTIRE lifetime warranty can be voided due to inaccurate mileage. I believe that is the only reason the entire warranty can be voided. Of course, even if you regear and you DO recalibrate the speedo, the gears you install will not be warranted by Chrysler. All of the remaining warranty will remain in effect as long as you do a recal on the speedo.
Old Apr 25, 2008 | 05:09 AM
Now I am confused. If I move up to 35's and don't calibrate the speedometer then my warranty is voided? Is that that how I am reading this or is it if I dont calibrate after regearing?
Old Apr 25, 2008 | 05:36 AM
08red6spd's Avatar
If you dont coorect for gear/tire changes it could void the warranty because your odometer is not correct.
Also, the gears may be less of a problem than the lift and tires. They may void some of your driveline warranty because the larger tires put more stress on the drivetrain.
Old Apr 25, 2008 | 07:10 AM
TEEJ's Avatar
Talking
Just to clarify a misconception - the GEAR swap does NOT affect the speedo/odometer/make it read wrong.
The tire diameter WILL affect the speedo/odometer/make it read wrong.
Bottom line - any mod has to be PROVEN to have CAUSED the warrenty claim, to have the warrenty claim be invalid.
WAAAAY back, I had a Stealership tell me that they would not honor the repair of my horn because I had "Voided my Warrenty" when I had installed an FM Converter.
I said, prove to me HOW the horn doesn't work because of the FM Converter, because if you can't PROVE it, you HAVE to fix the horn.
They fixed the horn.
Old Apr 25, 2008 | 08:49 AM
How can the gear swap NOT change the speedometer? Is the speed sensor for the speedometer on an axle? Seems like that would be the only way. I believe it's in the transmission, is it not? If so, the driveshaft speed will certainly be faster at the same speed with deeper gears, resulting in a faster speedometer reading. Changing the tire size in effect does the same thing. While it doesn't affect the actual gear ratio, it does change the effective ratio.
