Does Teraflex 2.5 lift need adj track bars
I have been going crazy this week tyring to balance money with performance. Finally, I have decided to with the 2.5inch Teraflex BB for my 2007 JK-4dr Sahara.
Has anyone installed this and reconnected the rear track bar to the factory axle bracket without a bracket adapter? If so, how much axle shift is there?
Is there a need for using adjustable track bars (rear or front)? I was reviewing WOL's install instructions and it appears that he reconnected the track bars to factor brackets.
Dazed and confused
Thanks
Dazed and confused
Thanks
If you reconnect the rear axle to the factory bracket, your axle is going to shift alot. Neither bar is needed to be replaced to run the 2.5 lift, though alot of people go back later and add a front bar.
JK-Forum Founder
exactly. while new adjustable track bars are nice to have so that you can recenter your axles, they are not needed. when i was running the TF 2.5" BB, i just ran it with my factory track bars.
Same here I have been running with the 2.5bb since May and kept the ome trackbars. I also took it in for alignment after the lift and added a new steering stabilizer. Been doing some aggressive trails with stock 32's and so far so good. Just a little diff draging.
I think when WOL did his BB install teraflex wasn't including the rear relocation bracket which the newer BB kits come w/. I have it on my 07 4dr sahara and am running the OEM trackbars w/ the rear relo bracket w/ no problems at all. I'm very happy w/ it and Joe at teraflex was great when I pestered him w/ questions via email.
I'd suggest adding the teraflex quick discos as well. You're gonna have it all a part anyway so might as well do it all at once.
