Doing lift now!
Old Aug 6, 2009 | 03:14 PM
JKjunkie2009's Avatar
Default Doing lift now!
Im in the proccess of installing a TF 2.5 coil w/ shock adapters. My questing is what should all the bolts be re tourqed to? Such as sway, track, and others......Is their a list anywhere? The instructions dont say!! Now i just have to get that darn Trackbar relocation bracket in!!!!
Old Aug 6, 2009 | 03:24 PM
So_Cal_Tay_12's Avatar
beat me to it
Old Aug 6, 2009 | 03:41 PM
falconfixer's Avatar
Good luck
Old Aug 6, 2009 | 03:44 PM
Originally Posted by falconfixer
Good luck
eh he should be fine, just as long as he's patient its a piece of cake
Old Aug 6, 2009 | 04:17 PM
Im trying to re attatch the track bar, and its connected to the nex bracket but its not long enough to reach the factory mount on the other side...it needs another inch. How do i get it to line up???
Old Aug 6, 2009 | 04:18 PM
it would help if i raise the axel back up
Old Aug 6, 2009 | 05:51 PM
Compress the suspension to line up the track bar, if the axle is drooping.
Old Aug 6, 2009 | 06:17 PM
tonkmaster's Avatar
Have fun with that....
Old Aug 6, 2009 | 06:43 PM
Okay! Got thise lift in yesterday, alonge with a PA 1" body. I put the body Lift on last night, and worked on the Lift today. Since this is my first jeep, and first lift install, I opted to take my time. I got everything done in the Rear, and set it down on the ground. Still a lil nervous, i will probably go back and tighten up everything for the 5th time!!! Had a couple of questtions tho.
1. The rear shock adapters have washers. Do i put a washer on the bottom, and the top of the adapter, or do the washers go on top and bottom of where the adaptor holds the shock down? I did the 1st one and i thinkg its wrong
2. Also, I have no winch or bumper, but ordered 1" coil spacers for the front. Did not realize how much highth people have gotten up front opposed to the rear, Should i still install the spacers?
Old Aug 6, 2009 | 07:08 PM
taht dedpends are u a 2 dorr or 4 door if it gives more than about 3.5 inches or so u may have driveshaft probs on teh 2 dr ugh i didnt know this when gettin my 2dr lol
the bl wont affect that part thos only in the frame likft
