Dome light switch Help!!!
Wouldn't be hard. Cut the wire that feeds the dome lights, cap off the side coming from the dash, then run a wire from the side that goes to the dome to the sPod source. The dome will only work with the switch.
If you want the dome to work normally but on the switch also, then run a power wire from the source to the dome light as an alternate power wire.
I believe it's the yellow/white wire running down the passenger side that feeds the domes.
Of course, test it before you commit to it.
Mine is not to reason why, mine is but to do or die...or something like that.
