Don't kill the village idiot...
Old Sep 1, 2007 | 03:27 PM
Roothawg's Avatar
Default Don't kill the village idiot...
Sorry guys. I'm new to the JEEP thing here. I've been trolling over the forum here trying to find out what I need but just can't seem to find it. I'm looking to run 16x8 wheel with 265/75-16s. I'm thingking of a 4.5 or 5" BS. My question is later on down the road I'm gonna want to lift it and get bigger tires so would I have any problems with these rims and their BS?
Old Sep 1, 2007 | 03:46 PM
mikeyfl's Avatar
im not 100% but you may run into rubbing issues, but nothing a spacer wouldnt cure?
Old Sep 1, 2007 | 06:25 PM
muddpuppy01's Avatar
you will be fine with the tire size you are getting down the ride it might rub a little bit
Old Sep 1, 2007 | 07:46 PM
FJ80fornow's Avatar
I am running 16 x 8 with a 4.6" backspace, and fit 35" tires on a 3" lift. The setup you are looking at will be just fine as you lift the vehicle. I would stay with the 4.5" backspacing instead of the 5", as this will keep you from rubbing as you put bigger tires on.
Old Sep 2, 2007 | 04:50 PM
Roothawg's Avatar
Kool. Thanks guys! I'm assuming I shouldn't have a problem with BS and spare tire carrier.
Old Sep 2, 2007 | 05:18 PM
schwarzjp's Avatar
You should be fine with the 4.5" back spacing and the fit with the tire carrier.
Old Sep 4, 2007 | 08:24 AM
wayoflife's Avatar
JK-Forum Founder
Stock BS is 6.25" and so you will be just fine with 4.25" or 5" even later down the road
