Door Sill Protection
Here's a quick cell picture I just went out and took.
I used something similar to the 3m tape ( pickup truck bed rail liner'). It worked ok. My problem was that I tried to use one wide piece to bend around from the inside across all the bends until it reached the 'outside'. The tape didn't have enough grip to hold itself around the final bend. If you do it on flat surfaces like the last pic you will be fine. But you can't have a tape edge that ends on a radius or it may peel up later on.
Good luck with whatever you do.
I actually used three strips. I'm sure it can be done cleaner than mine, since I did mine with insufficient lighting, used chalk to draw a straight line, and not-so-sharp scissors. With proper lighting a tools, it could be cleaned up some. I really don't think it looks bad at all. Personally, I prefer the look over the Mopar ones. The tape not only provides protection, but it also adds a lot of traction.
