The downside of 15" wheels?
Old May 11, 2009 | 03:10 PM
Default The downside of 15" wheels?
Provided that you have have no interference with the caliper and they fit, are there any downsides to running a 15" wheel on the JK?
Old May 11, 2009 | 03:22 PM
greenamphibious's Avatar
no... more sidewall is a good thing
Old May 11, 2009 | 04:18 PM
DaleRider3's Avatar
Offroad 15's are a plus, but if you're only doing highway driving the extra flex may be unsettling for evasive maneuvers. For some the 15's also make the tires look larger and they are typically $100/tire cheaper than 17's or 18's. Just have to be careful of which rims you pick or be prepared to grind a little on the calipers. My 15's fit fine.
Old May 13, 2009 | 06:25 AM
rjhoop's Avatar
Originally Posted by planman
They cost less, have more sidewall, come in a load range C tire (not as stiff), are lighter than load range D and E tires. The wheels are also lighter and cost less.
It really depends on your use.
Having run tires for 15" wheels and 17" wheels, I prefer the softer ride of the tires for the 15" wheels by far--even though I give up some performance/cornering ability. I didn't buy the JK for street racing and driving twisty roads at high speeds.
x2 ON ALL OF THE ABOVE
Old May 13, 2009 | 09:27 AM
Dunefever's Avatar
I also considered 15" wheels when I bought mine however I do not believe the JK came with 15" wheels and since I am going to Colorado with my Jeep on vacation there are some large down hill grades. I was concerned about the brakes overheating with less free air around them. I thought that with the R and D Jeep did if 15" wheels were doable they would have put them on standard and offered the 16" and 17" as an option to save cost. As a result I stuck with the 17"
Old May 13, 2009 | 09:36 AM
JPTwinz's Avatar
Nothing. Though the 80's called and may need them back once they're installled
You guys gotta give me some slack, I take a beating with comments on my 20's (installed on 40" tires mind you) so when I get a chance to reverse it on smaller wheels....
Old May 13, 2009 | 10:53 AM
Joe Lightfoot's Avatar
Sponsoring Vendor
Off Road Evolution Rep
I dont think I would worry about that unless your pulling a 40ft trailer
Old May 13, 2009 | 10:55 AM
Sponsoring Vendor
Originally Posted by JPTwinz
Nothing. Though the 80's called and made need them back once they're installled
Funny. Hey I like my old school 15s. 20s with 40s not to bad but I still like the smaller wheel look.
Old May 13, 2009 | 03:05 PM
ckmehl's Avatar
Default all personal
no everyone can afford to spen 10g's on just wheel and tire. however good your jeep does look. it's all a personal oppion on what they like. i love the look of 15's. i think it makes the overall look more agrressive. now if you have the money for the 20's with 40's. i would do it in a heart beat. the look is sick. but the average person can't. i would do what your wallet will let you do. it's a huge contraversy of the fitmit of 15's on the JK. some have problems so don't. it's a crap shoot. good luck with your choice.
Old May 13, 2009 | 03:22 PM
BaltChief's Avatar
I don't know how 15's fit....I know folks have them, but I don't know how. I have 16's and I have taped flat weights on the inside of the rim.....there is maybe 1/4 of clearance between the wheels and the weights. I can see how soft 8's and such that use clip on weights work but not one that uses taped weight.
