Drag link
Does anyone make one stronger that the factory drag link. I can't do the flip kit because I don't have enough lift. Mine is bent a little bit and would like to get this fixed before I get 35's
With the teraflex flip kit, you unscrew the bottom part of the factory drag link and discard it pretty much) and screw the new supplied one on in replacement to the correct length. You then drill the arm and put a tapered sleeve in and bolt the new drag link on (or half new to be exact).
So basically here is my idea.
If your drag link is bent at this lower portion, you could discard yours and locate a get a free drag link from soneone (like me?) who did a flip kit and then outer-sleeve it up to make it stronger (plug weld it in multiple locations), then bolt it on?
Just throwing out ideas.
I just purchased a factory drag link from someone on the forum. My problem is that I can't adjust the knuckle to center the steering wheel. Important lesson learned, don't use pliers or anything on the knuckle to adjust. A little PB Blaster and a strong grip should be enough.
