Drag link flip
Old Dec 27, 2021 | 04:53 PM
Sour Apple's Avatar
Default Drag link flip
I have a 2017 jku it has 3.5 in rock krawler kit with additional 1/2 or 3/4in spacer in front to level it better , I have 3 in of bump stops. I'm lookin to install rock krawler high steer kit with included track bar relocation bracket, try get rid of sum bump steer. Will it need more than the 3 in of bump stops? Will the t/b bracket clear? Everything is rock krawler I hope a bunch of yall have done this and it's fine with 3in. Thanks
Old Dec 28, 2021 | 06:11 AM
TheDirtman's Avatar
You might need another 1/2" of bump, you will know when you flex it out. You an always notch the frame for better clearance too. I would not waste the money on the RK high steer kit or anything else from them, but you already have their lift. You will find time will tell on their quality and so called warrantee. They really rip you off especially on brackets. I would recommend the Barnes 4WD B4WK12411 weld on bracket for $45 and go with an aluminum drag link with either heims or 1 ton TRE's. Barnes has a JK flipped draglink part number B4WK0288 for $215. You would qualify for free shipping with the draglink and they are more local to you.
Good luck.
