Which drag link flip kit?
I'm looking to install a drag link flip on my 2012 JKU w/ 2.5" RK Flex lift. Which one should I get? I'm not sure if I'm going to need a track bar relocation bracket or not.
the evo kit is good for 3" of lift. it is also a trackbar relocation bracket. it has my vote. $299 and done
just because the lift is called a 2.5" doesn't really mean anything. guys with 2doors are seeing 4" outta that kit with stock bumpers/no winch. its all based on how much lift you actually get after installation.
If you do go with ours, you might need longer bump stops. Depends if the 2.5" shorter or taller
Some more information: Although I have a 2.5" lift, I actually gained closer to 4" up front. I already have longer bump stops that I installed with the RK kit.
Just to clarify, If I get the evo kit, the bracket will work with my RK trackbar?
