Drag Link or Tie Rod
So, I have managed to bend both by drag link (slight bend) and my Tie Rod. I have $350 set aside to buy one or the other. I have been reading up on it, but just want to get other folks opinion before I buy. While I will get the next component within the next 3 to 4 months, I will be off roading quite a bit between now and then and have a 3-day trip over thanksgiving at Super Lift Off Road Park.
Help!
Help!
Not much to look at both bends are pretty mild. The jeep still drives ok... just a question of which one I should fix first. I was thinking the tie rod as it is more exposed to additional damage and the drag link later. But, how bad is a slightly bent drag link?
You can adjust each of them to work with a slight bend. Neither would be urgent until they are bent to the extent they cause interference or cannot be adjusted to specs.
I'd think that if you wheel in the rocks, locked, with large tires, the tie rod would be bent beyond useable specs 1st.
also, are you sure that your drag link is bent? because, they are bent a bit right from the factory and if you didn't know as much, you might think that the bend is new.
Yes... pretty sure it is. I had to re-center my steering wheel after the incident. I managed to get my wheel stuck against the pin of the lower sway bar link on the passenger side when I came off a rock. I had initially thought I broke my tie rod, but the bend in the drag link was pretty dramatic. Once I managed to unstick the wheel, the drag link straitened out a bit but not all the way.
For those wondering...that is Gilmer Texas.
