drag link with tie rod ends question
ok so i installed my new bds front adjustable track bar and had to re-center my steering wheel which i've done b4 and i loosened the two nuts and could not turn the drag link but just a lil and now the esp is making it impossible to drive so im gonna order "rock Krawlers" new hd drag link and ive never messed with tie rod ends which the new drag link requires , do they just come right off when that top nut is unscrewed or do i need a special tool to remove it? and any advice in the mean time on how to deal with the old drag link? any other way to re-center the steering wheel?
Use a pitman arm puller, don't use the pickle fork (as pictured above) unless you don't care what the rubber boots are going to look like afterwords. I am speaking from personal experience. A pitman arm puller can be had from harbor freight for less than 10 bucks.
well thanx alot, i really appreciate your help. i can definitly save money doing this myself i just seems so easy to do. on the drag link unscrew the bolt hit it with the dead blow hammer and it should come out and to insatll i guess just pop it in..
and i guess its the same for the tie rod since its the rock krawler setup i wont be using the ends...
well thanx alot, i really appreciate your help. i can definitely save money doing this myself i just seems so easy to do. on the drag link unscrew the bolt hit it with the dead blow hammer and it should come out and to install i guess just pop it in..
are those the moog tie rod ends? well im just waiting for the moog rod ends to come in, i removed both bolts to the drag link and it wont come out not that i tried hard since i have to get the tie rod puller. i hope this setup is easier to re-center the steering wheel. i pick up my moog ends tomorrow (thursday the 21st.) along with the puller and i'll post my results, easy or hard to remove.... thanx for the advice, pics and help...
yeah, no one had them in stock and had to be ordered $83 bucks left side and the same for the right for the drag link, thats the reason why i didnt get the tie rod at the same time the damn rod ends are more than the rockkrawler part, but i gotta say its HD..
wow that pitman arm tierod end was a pain but I can't use my steering stabilizer relic. Bracket. I have to put it back to the stock location, any ideas?
