Draglink removal-Need help
Old Jul 13, 2014 | 11:21 AM
ZombJep's Avatar
Default Draglink removal-Need help
Anyone have any suggestions on removing the pitman arm side of a draglink? Been banging on mine and it wont come out.
Old Jul 13, 2014 | 11:26 AM
Smashboogie 4x4's Avatar
Former Vendor
A ball joint separator should do the trick.
Old Jul 13, 2014 | 11:31 AM
ZombJep's Avatar
I don't have one. I guess if all else fails I can go get one. Thanks.
Old Jul 13, 2014 | 11:42 AM
JDub23's Avatar
Local auto store can usually rent / loan one to you.
Sent while my wife wasn't looking...
Old Jul 13, 2014 | 12:49 PM
D_engel's Avatar
Do you need to salvage the TRE? A pickle fork will get it apart but the rod end will be shot. Usually hitting the pitman arm with a BFH will compress the taper and the joint will pop out. If that fails, I recommend trying to get a pitman arm puller positioned with a series of socket extensions running through the engine compartment to the puller. It should pop right out
