Dreaded death wobbles and suspension fix
Old Sep 21, 2009 | 08:03 PM
  #21
Hellbound13's Avatar
Originally Posted by 07wranglerxS
Hey i installed a 2.5 rough country bb about three months ago and that evening took it for a spin and sure enough hit bump going 60mph and the whole jeep just shakes like it is about to fall apart scared the s!!! out of me. But i did a lot of research before i replaced anything and this is what i ended up doing with my stock tires still on and the steering stabilizer off i adjusted my toe out to 3/8 and yes it is toe out instead of toe in because the tire is adjusted outward just a little instead of inward just a little and this solved my problem with stock tires and no steering stabilizer even on the jeep and no dw at all now but if you have drove the jk like that and had several dw events than you could have toasted your ball joints especailly your upper ball joint and that in itself can cause death wobble by the way dynatrac is going to release soon some heavy duty ball joints for the jk just a heads up because the stock ones are junk
Where can we get these new ball joints?
Old Oct 9, 2009 | 02:57 AM
  #22
slacktide's Avatar
Originally Posted by chip80
The springs you installed effectively decreased you caster, which is most likely what caused the DW. How did you adjust your caster??? Since there is no caster adjustment on the stock JKs. Installing adjustable control arms will allow for caster adjustment.
I had the same DW problem after installing a 2.5 lift. Teraflex rep at Moab EJS said that moving from 33 to 35in tires would effectively increase caster. I installed a set of 35s and haven't had the DW since.
How is this working for you now? I have 2.5"BB tera flex and now have DW. I checked for play under the jeep while i had someone move the steering wheel. Everything seemed to be tight.
Im going to double check the track bar and torque the bolts to 125
I have 33s
Im looking to buy the 3.5" AEV pre lift will the new track bar fix this?
Any help please
Old Oct 9, 2009 | 06:48 AM
  #23
I have 33s
Any help please
Check the track bar holes to make sure they are not wallowed out.
Old Oct 9, 2009 | 06:52 AM
  #24
aBē's Avatar
Can a loose sway bar link cause Death Wobble? Death Wobble has come I installed a JKS Front Trackbar, but the drivers sway bar link is loose, can this be the cause?
Old Oct 9, 2009 | 07:04 AM
  #25
robin's Avatar
I read on another forum that your jeep rides really harsh on some streets, that's not exactly dw now the question about the sway bar, I've had the sway bar discoed for about 5 months (I forgot about it) and I feel the jeep really leaning on tight curves but that's about it so I don't think that would be causing it. There are really good shops in Guadalajara, I'M surprised you're having this problem
Old Oct 9, 2009 | 07:14 AM
  #26
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
You can buy them from Dynatrac. They should be available soon. They are not cheap though. $600 for the set.
Old Oct 19, 2009 | 03:21 PM
  #27
aBē's Avatar
So do you already find the cure for DW?
Old Oct 19, 2009 | 03:34 PM
  #28
Are you sure you have full on DW, where it shakes the whole Jeep until you slow down to a stop?
Old Oct 19, 2009 | 03:54 PM
  #29
aBē's Avatar
The wobble stops until I slow down (only in rough streets when I hit bumps)
Old Oct 19, 2009 | 04:06 PM
  #30
What speed does it happen at and what speed do you have to slow down to in order to make it stop?
Had you changed anything on your Jeep before the DW showed up?
