Drilling into underside of hard top
Old Oct 18, 2021 | 05:09 PM
JeeprCreepr13's Avatar
Default Drilling into underside of hard top
Any experience here with drilling into the underside of a JK hard top? I want to mount some netting and a snow scraper holder. Thanks!
Old Oct 18, 2021 | 09:36 PM
Sv_dude's Avatar
5 Year Member
Loved
Community Favorite
It’s just fiberglass. If you really want to put a hole in it then you would be better Kay to do it. Be sure to use a rubber washer on the top side of the bolt so you aren’t introducing any water leaks. You can also use silicone too.
Another option is to use Velcro for a quick fist type mount for the ice scraper. You can possibly use glue to glue some pads to the inside of the top. Those pads can hold a snap for each corner of the net you want to use. Just some alternative ideas so you’re not drilling the top.
Again, it’s just fiberglass so you can always fill the holes you drill with some epoxy and fiberglass powder mix.
Old Oct 19, 2021 | 07:36 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Just to expand a little on what SV advised. Same thing but when you drill through it the roof is double skinned with a hollow center in most places. What I would do is what SV said but add a fiberglass or PVC tube the size of the bolt and the width of the two separate skins. Glass or epoxy it in which will leave you with a solid mount to tighten the bolt against - not too tight though. So to recap EG if you had a 1/4" bolt then the top hole to the exterior will be 1/4", then the tube might be close to 1/2" diameter with 1/4" inside and that will slightly protrude through the bottom skin to the interior and be glued in place. Drill the larger hole in the bottom skin and do all the tube fitting and epoxying first then drill the hole through the top skin after glue is dry. Bit long winded for just a hope but roof leaks are no fun.
Old Oct 19, 2021 | 02:44 PM
chiapeteater's Avatar
If it was me, and I have thought about doing this to the freedom panel to put an overhead Ram Mount, I would drill through the first layer and then install a rivnut rather than drilling all the way through. Just be careful tightening the rivnut and use some epoxy or something like that on it when installing it so it can't spin on you when you tighten or loosen your fastener.
If you are trying to make a storage attic for sleeping bags and such, I just purchased and installed the Blue Ridge Overland Gear Storage Attic in mine and installation was a breeze. https://www.blueridgeoverlandgear.com/collections/vehicle-attics/products/jeep-jku-attic
Not the greatest pic but you get the idea….
