Drive Shaft...
Old Mar 6, 2011 | 05:15 PM
funtimes's Avatar
Default Drive Shaft...
Hey whats the best drive shaft??? just kidding...But really now, i want to remove front drive shaft for my drive to EJS, is there any problem with this? Do I have to put in 4hi every now and then to lubricate transfer case? just curious...
Old Mar 6, 2011 | 05:19 PM
Pluke the 2's Avatar
id pick up a spare front ds for $50 and haul it out there.
Old Mar 6, 2011 | 05:32 PM
nthinuf's Avatar
You'll be fine. This was talked about a while back, and the verdict was that there is something inside the case that will lubricate the front half when that driveshaft is removed.
I have seen several posts from people that run without the front shaft full time, and only swap it back in while they are on the trail.
Old Mar 6, 2011 | 05:37 PM
mkjeep's Avatar
I drove mine 1500m to Moab last year without a frt ds,put it back in when I got there, you'll be fine, no need to do anything special
Old Mar 6, 2011 | 05:59 PM
funtimes's Avatar
Originally Posted by ECHO
This may sound stupid.. but: why remove it to drive out there?
because I just got an aftermarket one put on and don't want to take the chance of blowing my transfer case out on the 1200 mile drive there due to any vibrations.....that would be a bad start to a vacation...Seems to be a safer bet to take it off for the drive and put it back on down in Moab...
Old Mar 6, 2011 | 08:41 PM
Runewolf1973's Avatar
If it's installed correctly, how should that be an issue? I'm looking into getting an aftermarket front driveshaft installed in my JK also, but not sure what to expect.
Old Mar 6, 2011 | 09:00 PM
mkjeep's Avatar
Several people, including myself have suffered Tcase probs and failures as a result of what we think is running a combo of lifted , re-geared, and castor issues causing the front driveshaft to vibrate at high mph. Castor and pinion angle- we have to try to find a happy medium and or minimal vibration. It's suspected that once the driveshaft reaches a certain harmonic frequency with the vibes and sustains it for a period of time, BOOM!
Better safe than sorry, I pull mine on long trips.
Old Mar 7, 2011 | 01:09 AM
DCJEEP's Avatar
Hmm this is every interesting and somthing I didn't know. Thanks for the info guys. I always take long trips in my jeep.
Old Mar 7, 2011 | 03:36 AM
funtimes's Avatar
Ditto...thanks for answering that for me, you said it much better than I would of..
Old Mar 7, 2011 | 03:51 AM
funtimes's Avatar
So just out of curiosity...what would happen if you ran it in 4hi all that way going 70mph without a front shaft on... Nothing? Parts would fly off? Anything?
